M35a2 idling funny
w250guy
21
Stamford/vt
So just got my in tank fuel pump working correctly by making some new plates/shims and a new cover plate with strainer. Also changed all the fuel filters. Turned the pump on and it was spewing fuel out of the bleeder within 15 seconds id say. Truck runs great but at an idle it will idle smooth then kind of stumble or chug a little then smooth out again and repeat like “smooooooth chug chug chug smooooooooth chug chug chug i dont know what else to try to remedy the problem or is this kind of normal? Im running 80/20 - diesel/new 15/40 maybe even closer to 85/15 any thoughts on this?
yolner
68
Rockville, MD
I had the same issue once and couldn't figure out what it was either. Just seemed to go away on its own. Maybe air trapped somewhere?
porkysplace
1,485
mid- michigan
When is the last time you changed the filters ?
Do you drain the primary filter for water and other crap like it says to do in the -10 TM ?
w250guy
21
Stamford/vt
I just cleaned everything and new filters yesterday, its acting like its starving for fuel almost but only at an idle. It seems to run and drive just fine.
w250guy
21
Stamford/vt
Its right around 700-750, i did take it to work this morning and it seems to be idling alot better now
