M416 Rear Light Assembly/Mounting Bracket
Steel Soldiers is supported by:
90Jimmy
Southern Illinois
I’m not sure if that would work or not. Thank you sir for the effort, thinking it may be easier to just fabricate the part.
If you happen to have an M1009 seat bottom tucked away in that loft, I could use that.
cucvrus
294
Jonestown Pennsylvania
What side on the seat bottom? Must the fabric/vinyl be good? I still have a few taillamps I removed from M416 trailers. I want to look if they have a bracket.
M813rc
32
Near Austin, Texas
There are two types of light bracket for the M416, one for the small tail lights, another for the big ones. The one for the larger lights, obviously has a longer outer arm to clear the trailer and lift the light up a bit more.
My trailer has the larger lights, but the short brackets, with spacers between the base and the trailer. Looks a bit odd to me. If I ever find a set of the longer arms (I tried a few years ago, with no luck), I'll give the shorter ones to someone who needs them.
Cheers
90Jimmy
Southern Illinois
It’s the drivers seat bottom I need, thought maybe they were interchangeable with some parts moving... with no damage would be desired, I know this is hard to find.
