mep-005a looking for short block/complete engine or crank and piston with rod
Steel Soldiers is supported by:
generatorshawn
gainesville fl
got a mep-005a thought i did good when the guy i got it from a system swap and it had run original owner told him that it had a stuck valve but would run, till i took the oil filter housing off and found a rod sticking threw the block lol. anyways hoping someone has short block or the pieces i need to replace the ones that are broke would need a new crank and the entire piston assembly with the bearings. maybe a complete motor if someone has a good deal on one.
cheers.
