I have a problem with 3kw generators.
the first one is from GL and it was new I got it running but the 28 volt surges
with a load the voltage turns on and off it will do it under no load as well if you play with the regulator adjustment the engine sounds like it is hunting. I do have a spare new regulator.
Any help would be welcome.
I have a problem with a used 3kw 60hz machine as well the regulator the mag coils and the carb as well I have replaced all of the above. I have add a starter as well.
I can it running but I need to adjust the little T handle on the card as it warms up
for a rope start it needs to be 1.5 turns out and as the unit warms up it needs to be turned in is this normal?
I have also noticed that the load meter does not show the load from the 2 120 volt outlets
is this normal? I am using a 1600 watt hair dryer the frequency moves less than 1 cycle.
thanks in advance
thanks in advance
