VT MEP-803a Generator Parts
Steel Soldiers is supported by:
Evil Dr. Porkchop
50
Colchester, VT
Selling some parts removed from a military mep-803a 10kw diesel generator. It had a stuck engine when I got it. Located in Colchester, VT. Prices do not include shipping. I take paypal if you cover the fees. The other parts pictured on the set that aren't listed below are available as well. The following parts are sold: complete gauge cluster, fuel shutoff and linkage, starter, voltage regulator, frequency transducer, throttle cable, short circuit / overload relay, injector pumps, float switch module, coolant overflow bottle, alternator and brackets, upper radiator hose, fuel tank, and the doors not pictured on the set. The generator head is no good.
Exhaust manifold - $50
Intake manifold - $50
Water pump / fan - $50
Slave port with cable - $30 - cover is broken
Injector lines - $50
Fuel pump - $40
Intake hose - $20
Injectors / brackets - $50
Overvoltage relay - SOLD
Pulley - $10
Radiator (no hoses) - $100 - I don't want to ship this, pickup only
Lower Radiator Hose $25
Small door - $60
Big door - $100 - has a small dent in it
