military version or civy conversion
scoutmanadam
richland, washington
someone close by is selling a truck i am going to go look at in the next day or two. it is a deuce but with a body on it i have not seen before and was wondering if this was a military conversion or a civy one. its a 63 rio whittenburg gasser
73m819
314
gainesville, ga.
wow, a very compleate line truck, good find, 100% military
jatonka
56
Ephratah, New York
That is a V17 AMTQ telephone line truck, it's sister is a V18A MTQ pole setting truck, they are both uncommon. I have 1 and 1/2 V18A MTQ trucks, wish I had the one you are looking at.
73m819
314
gainesville, ga.
A lot more pics would be nice, really looks in great shape, put a multi in it
scoutmanadam
Sad, just got a call from the guy, it has no title, and needs a front axle. he said he would sell it for scrap price and those are his plans for it after thursday. he says he has already hauled six of these to the scrapper this month. rear winch works and everything else is good. if it had a titile i would save it in a second but now....
wreckerman893
Possum Connoisseur
15,611
1,981
There's more than one way to skin a cat......there's just no way to make him like it.
Save the truck....worry about the title later.
They are rare.
In Alabama you can get a tag and registration (but no title) for any vehicle prior to 1976 with just a Bill of Sale.
Check you local laws.
If nothing else you can save it for someone in a less rigid state.
maddawg308
723
Front Royal, VA
No title, no problem.
Front axles aren't rare, they are common.
SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT SAVE IT
scoutmanadam
ill talk to him again tomorrow, he said he got them from his neighbors farm when it went bankrupt and he got them from the department of the interior. he had titiles for all but this one and said he could write a bill of sale, i will check the law tommorow. he said he would also take a trade straight across for my deuce minus my winch which i would keep and add to that truck.
hndrsonj
Senior Chief/Moderator
358
Cheyenne, WY
I'd swap in a second.
m16ty
210
Dickson,TN
There's no way you could go wrong paying scrap price for this truck.
When you say "front axle is bad" what do you mean? If it's the center chunk that is bad, they can be found anywhere for cheap. I've seen rear axles go for $200 that uses the same guts. If it's got a bad axle shaft it could just be a failed axle joint (this truck will more than likely have the claw type joint). So unless the front axle is literally broken in half you should be able to fix that fairly cheap.
73m819
314
gainesville, ga.
the front end problum could be nothing more then not pulling because of a out of adjustment sprag
