TN MK48 RBU axle set bogie. 5.57 ratio w/ lockers
Steel Soldiers is supported by:
simp5782
I'm the dude, man!
7,640
153
Memphis, TN
Oshkosh MK15A1 Rear Axle Assembly - MK48 M984 - 5.57 RATIO RS580 EATON. Condition is Used.
This is the rear axle assembly with parabolic springs from the MK48/MK15A1 wrecker and other RBUs It is the same setup used in the M984 wrecker but with different wheel studs. Wheels and tires are not included with it. Again This axle setup with fit all RBU units. MK14 thru MK17 or fab it to something else.
Detroit lockers in both axles with a front axle having a power divider. 58,000lb rating RS580 setup. S CAM brakes. Comes with between the tandem driveshaft. Yoke takes a 1710 companion flange for the front and tandem input.
Includes axles x 2, brakes, mounting brackets, torque rods, hubs, springs.
I had got this for a project but ended up locating a whole RBU instead.
Located in Memphis.
$2800 obo
