Again, sorry for my ing'nace WRT this unit, the mechanic not available til tomorrow so I again ask indulgences here because I'm new to this whole issue. I'm most appreciative WRT any kindnesses offered by experts.
Seems if I put the FSS in its running position manually with a block the genset starts ok,. As soon as I pull the block the solonoid shuts the unit down. Oil pressure at 100, mild smoke from one exhaust.(but I don't want to run it long enough to heat up so maybe it will go away when it heats up, was told it doesnt smoke) Also as set currently the HZ meter is high at 65, but the engine is not at load.
Any authoratative guidance/recommendations/suggestion are appreciated. I can respond in kind WRT comprehensive medical or weapons issues if that would be desired.
