UT NOS Mil-Spec Hardware & Buckles
Valence
196
Davis County, UT
For the Do-It-Yerselfers out there, I have a number of New Old Stock (NOS) genuine mil-spec black buckles for various webbing sizes. Note: None of these buckles are intended for life safety devices.
Note: I have had to start selling these as lots due to recent steep increases in the fixed portion of transaction fees. I apologize for these factors out of my control.
Prices are per lot as indicated + shipping
Located in Kaysville, UT 84037
5/8" (14 mm) Double Bar Buckle, lots of qty 10 $5.50
  • Quantity: 10
  • For approx. 5/8-inch (14 mm) wide webbing
  • Meets Military Specification MIL-B-543G (Type II, Style 3, Class 3), and MS51944A-8
  • Overall Length: 1.05″
  • Overall Width: 0.74″
  • Strap Accommodation Width: 0.61″”
  • Smallest opening allows ~0.05″ thick webbing (~0.10" when webbing is doubled)
1" (25 mm) Brass Ball Tip, lots of qty 5 $5.50
  • Quantity: 5
  • 100% Brass (non-sparking, non-magnetic).
  • Meets MS51926B-3.
  • For 1-inch (25 mm) wide webbing.
1" (25 mm) Steel Snap Hook (non-swivel), lots of qty 5 $8.00
  • Quantity: 5
  • Meets Military Specification MIL-S-43770/1A
  • Overall Length: 2-1/8″ (54 mm)
  • Overall Width: 1-3/8″ (35 mm)
  • Width of Hook: 5/8″ (16 mm)
  • Hook Size (effective area): 1/4″ x 1/4″ (6.3 mm x 6.3 mm)
  • Wire Thickness: 0.135″ (3.4 mm)
1" (25 mm) Heavy Steel Cinch Lock Buckle, lots of qty 5 $9.00
1" (25 mm) Steel Spring Clamp Buckle, lots of qty 5 $8.00
  • Quantity: 5
  • Meets MS51929A-2 (also see dimensions figure Row “DASH NO. 2″)
  • Overall Length: 2-3/8″ (60.3 mm)
  • Overall Thickness: 5/8” (16 mm)
1-1/2" (38 mm) Brass Ball Tip, lots of qty 5 $8.00
  • Quantity: 5
  • Meets MS51926B-5.
  • For 1-1/2-inch (38 mm) wide webbing.
1-1/2" (38 mm) Steel Cinch Lock Buckle, lots of qty 5 $8.00
May have minor surface corrosion and other finish discolorations due to age and storage but this will not impact the functionality of the buckle. Though I have cleaned the buckles twice, there may still be trace amounts of oil residue.
  • Quantity: 5
  • Meets Military Specification MIL-B-543F, Type III Style 3 Class 3
  • Manufacture Date: 12/1989
  • Overall Width: 2-1/8″ (54 mm)
  • Overall Thickness: 3/8″ (9.5 mm)
  • Strap Accommodation Width: 1.53″ (38.8 mm)
  • NSN: 5340-00-805-1055
1-1/2" (38 mm) Steel Spring Clamp Buckle, lots of qty 2 $5.50
  • Quantity: 2
  • Brand New
  • Certified mil-spec and meets MS51929A-3 (also see dimensions figure Row “DASH NO. 3″). Not intended for life safety devices.
  • Overall Length: 2-5/8″ (66.7 mm)
  • Overall Width: 1-7/8″ (47.6 mm)
  • Overall Thickness: 15/16” (23.8 mm)
Valence
196
Davis County, UT
NEW:
Clevis, Shackle, Bumper, Rigging, Container, Shelter, Lift, 7,000 lb Proof, $8.00 ea
Multiple available, save 10% when you buy 2+, save 15% when you buy 4+, save 20% when you buy 8+
Vintage new old stock (NOS) off-set shackle with black conversion coating. 1/2″ (12.7mm) thick steel tear-drop clevis/shackle. Used in various military trailers, bumpers, containers, lifting and other such general applications. Will show surface corrosion in places due to age and storage. 3/8″-24 hex bolt included.
  • NSN 1670-00-893-1631 (5340-00-893-1631)
  • MFG P/N MS70085-1
  • 7,000 lb (~3,175 kg) Proof Load (Note: This is not the same as Working Load)
  • Manufacture Date: 1981
  • Meets or exceeds MIL-C-40137A (Clevises, Rigging, Air Delivery Type. General Specification For)
  • 1/2″ diameter steel tear-drop loop (AISI/SAE 4130/4140)
  • 3/8″-24 hex bolt included
NEW:
P38 Pocket Can Opener, lots of qty 2, $3.00 per set of 2
This iconic foldable manual can opener can be placed on a key chain, lanyard, dog tags, zipper pulls, go bag, food storage, or virtually anywhere so you have a simple, yet effective means to fill up your human fuel tank from scavenged "old-world" tin-cans. Useful for any task that a needs small blade, from opening Mylar bags, stripping wires, cutting fishing line, gutting fish, cutting boxes, bottle opener and more!
Sold in lots of 2. Pictured mil-spec split connecting rings included.
Purchasing a quantity of "2" of this item will get you quantity 4 of P38 can openers with rings, a quantity of "3" will be 6 can openers and so forth.
Multiple available.
  • Quantity: 2
  • Included 1" split connecting rings, NSN: 5365-00-827-7115
  • 1-1/2" long
  • 5/8" wide
  • Manufacture: US GI Shelby Company
