TN Parts Parts Parts
Steel Soldiers is supported by:
simp5782
Feo, Fuerte y Formal
1,444
Memphis, TN
Rebuilt in the can HT740D - $2500
Rebuilt Oshkosh 30000 HET/MTVR Transfer Case - $3000
Complete Meritor 22,500# trailer axle - complete with brakes and hubs for MTO20 Trailer - $600
Same Axle with drums but no brakes - $500
RG31 MRAP Aluminum radiator/intercooler/oil cooler combo for M939 retrofit - slight intercooler damage - $650
Complete Big Cam I 390hp engine - No bellhousing, air compressor or injection pump. - $3000 - sold
M939 3/4" stud combat wheels with new o rings - 4 available - $125 ea - SOLD
Cash or stripe payment with the fee. No paypal
simp5782
1,444
Memphis, TN
-HT740/HT754 Hydraulic shift PTO - used - $1000
-CAT 7155 PTO - used - no adapter plate- $300
-M809 transmission PTO - used - $300
-Mk48 rear axle assembly both axles with suspension- 5.57 gears - $2600
-New in crate CAT 7155 transmission $3000
- Used CAT 7155 transmission $1500
-Allison MT654CR for NHC250- used take out - $1200
- 3.5in HET 5th wheel plate - $500
-20,000lb pusher axle from m920 - $1250
simp5782
1,444
Memphis, TN
Bump
M809/m35 series hard top. Complete $500 - SOLD
Oshkosh 18000 transfer case from 916/17/20 $1600
M916/917/920 front axle with springs hub to hub $1600
simp5782
1,444
Memphis, TN
-M939 spring brake cans - 4 available- take offs $250 each shipped
-5 ton 3rd member - removed unit- $500 plus freight
-M939 passengers steering cylinder NOS- $350 shipped
-M939 drive axle backing plate air brake spider- $150 shipped - no spring cans.
-HT3B turbocharger - Low Hours since rebuild - $600 shipped
-M939a2 spring brake holding brackets- 3 available- $50 shipped.
-MK48 Hydraulic tank $160 plus freight
-150ft of 7/8" steel cable $120 plus freight
- M809 front winch driveshaft - complete - $100 plus freight - SOLD
- m939 soft top - tan - New in box $350 shipped
simp5782
1,444
Memphis, TN
M939 dash unit w/ gauges and air cables - $250 shipped
M915 series battery box with solid top - $200 plus freight
M915 series battery box without top -$100
M939 heat exchanger - $200 plus shipping
simp5782
1,444
Memphis, TN
•M39/m809 winch frame extensions - $350 shipped for complete setup - will not fit 939 trucks.
•M939 Abs relay front/rear - take off - $120 shipped each
•ISO bed spare tire arm - $150
•M915 front bumper - $150
•M915 pad eyes - $160 pair shipped
•NHC250 aluminum oil pan - $120
•Take out HT754CR transmission from M915A1 - $850 - SOLD
• m939 take out-complete front driveshaft with center support bearing -$250
•M920 5th wheel ramps $200 pair
•3.5 inch 5th wheel plate from m916/920 -$200 - SOLD
• large aluminum air tank - needs fitting welded- cracked - $150
• new Spicer yoke 6.5-4-2561-4 for 1810 u joint Oshkosh 55000 transfer case HET - $120 shipped
•air tanks for M915 series- 3 available - $75 ea
•round 5 spd transmission storage container $50
simp5782
1,444
Memphis, TN
•M809 M939 Take off Ross steering gear box - NHC250 Trucks only - $450 shipped.
•M915-M920 Ross series steering gear box - used - $320 shipped. - SOLD
•M916 THRU M920 Rear walking beam complete assembly with lockers - complete $4000 - SOLD
