Problem after over Voltage,Who can help?
trackdriver44
Belgium
My friend had a problem with his alternator and had overvoltage.Since this problem the Controllamp on the dashbord from his M9 serie light always up.It was not before.What can be the problem?Thanks a lot
74M35A2
312
Livonia, MI
Welcome. Problem is likely ABS, which is common to have trouble after over-voltage. Is control lamp on dash board you are speaking about a small yellow light?
74M35A2
312
Livonia, MI
The over-volt likely damaged the ABS module or fuse. The yellow light is for ABS fault. Engine function is likely unaffected.
