Putting together a 80mph speedo kit.
Mattguy
1,329
Highland, Indiana
I've slowly got almost all the pieces for a 80mph electronic speedo conversion. Have everything except transfer case electronic sender and what looks like a diode board. Has anyone installed the kit? And is the diode board necessary? I can't even find a PDF of the installation instructions from the kit and all the tm's just show parts numbers and diagrams. The kit number is 57K4882.
  • Like
Reactions: OBX
springer1981
1,148
Maine
Not sure what a diode board is, the drawing doesn't show it. There is a resister board but that doesn't seem to be a part of the wiring but maybe to relocate the heater resister for clearance issues? Do you have a cannon connector on the back of the speedometer or a terminal strip?
Mattguy
1,329
Highland, Indiana
Its number 10. That must be for the heater and it is a resistor board like you said. Weird that it's part of the speedo kit. Now just to find the backordered #7 speedo sender unit. I'm also trying to figure out where the 2 y taps go. I know one is for power, and i assume the other is for the backlight.
springer1981
1,148
Maine
#10 is the resister relocate board.
Mattguy
1,329
Highland, Indiana
Thank you @86humv! Got my sender today and hopefully I'll try to install this weekend. Still looking for instructions for installation can't figure out the under dash wiring part.
Repeat buyer from 86humv. Great guy.
badgerd
Electronic Jedi
102
Chesapeake VA
Here’s some notes I made after doing mine (and my own built harness). Cable numbers and locations are correct, I’m still looking for the “official” instructions as well but it works just fine!View attachment Electronic Speedo Install notes.pdf
You do need splitters, and not normal ones, to get power and light to the gauge. They’re shown in the manual pic on the last page. Easy to make, so I’ve never looked for them.
Mattguy
1,329
Highland, Indiana
Here’s some notes I made after doing mine (and my own built harness). Cable numbers and locations are correct, I’m still looking for the “official” instructions as well but it works just fine!View attachment 894024
Thank you! I have the harness, 2 splitters, sender and speedo. Along with the clips and screws in the TM . This will help me out!!
Mattguy
1,329
Highland, Indiana
Did you run the harness thru the place where the speedo cable is at? I didn't see the picture where you put the harness thru.
badgerd
Electronic Jedi
102
Chesapeake VA
Yup! I removed the grommet from the old cable by cutting a slice in it and put it on the new harness. I followed the speedo cable for install and grounded to the transfer case by changing the ground lug to a slightly larger size and using a bolt on it.
When I put that together it was raining so I didn’t take pics of the harness install. Maybe someday I’ll update it.
