rusty (no leaks) gas tank
billyzz
rapid city sd
am gonna use either muriatic or phosphoric acid for the rust.
i have seen sealers fail before and thats worse than rust.
i will get it clean clean clean then slosh alcohol around in it to remove all traces of water
then splash diesel to coat the innards
then i will just keep the tank topped off with fuel
M543A2
10
Warsaw, Indiana
We add Marvel Mystery oil and Lucas fuel conditioner to our fuel. This prevents rust and also helps prevent carburetor corrosion from the current cruddy quality alcohol content fuels. Your full tank idea is also good.
Regards Martin
