Shift lever light replacement
tkdtim
Green Bay, WI
Anyone replaced the light in the shift lever? Is it a replace the unit or replace the bulb type setup? Mine comes on sometimes and sometimes not (same as my jeep lol). If I tap on the shifter it flashes in and out. Must be bad connection. Do you remove the entire assembly?
ryanruck
Cincinnati, OH
I have. It's supposed to be a sealed unit. Mine wasn't so sealed any more and that could be your problem too.
Take out the shifter assembly and it unbolts from the bottom of it. While you're at it might be a good idea to install some aluminum rivnuts to make future shifter removal a lot easier and replace the likely rotting rubber boot.
tkdtim
Green Bay, WI
After digging into it, it seems the light grounds through the shifting linkage or something. Only wiggling the linkage underneath makes the light go off and on. I say it must be a ground because this is only moving the link to make contact with the shifter, not actually moving the shifter. I'll clean up the contact surface and try to tighten it up a little as there is a lot of play.
Styk33
0 Star General
Sacramento/CA
What's that part called? My truck doesn't have the piece that has the lights or the letters to let me know what gear I am in.
tkdtim
Green Bay, WI
Hmm any idea why wiggling that linkage and nothing else would cause the light to come on? Its called
HMMWV Military Shift Indicator Light M998 on ebay
