TX Stewart & Stevenson M1079
Steel Soldiers is supported by:
thtrev2001
San Antonio, Tx
2001 Stewart & Stevenson M1079 4x4 EMP-Proof Military Truck Camper $34,995.00 OBO
Low Mileage, Street Legal, Excellent Condition! - Perfect On or Off road!
-Cat 3126 with 275 horsepower. this engine is highly dependable
-Heavy Duty Allison 7-speed automatic (push button)
-5 Like new (98% tread ) tires (Includes new spare)
-4 Hawker military batteries
-Battery cutoff switch
-Storage box with 2 military 2KW generators
-Adjustable AIR RIDE CAB
-Street-legal, TX plates, clean title in hand
-EMP-Proof (Electromagnetic pulse ) Great Prepper option
-Transportable stairs that easily attach for easy entry and exit
-LED flood lights mounted on either side of box
-Turn Key 100% Ready To Go Work Or Play
Interior:
The interior is what you would expect from the military, the drive cabin has 3 comfortable seats and plenty of cargo room and mounts for a table. Everything works as it should. The rear insulated camper is bare and ready for build out. It has a pre-set 120/208V/2PH/100A/60Hz power distribution panel that controls permanently mounted 120V electrical outlets placed along walls- all lighting and power in the back is already wired and works.
We have had an electrician hardwire a 120v 50 amp plug to use at RV campsites or run off a generator. Includes 24VDC emergency and blackout light system The windows open easily and the doors allow plenty of access for new cabinetry and ventilation.
All the lights operate as they should.
Drivetrain:
This beast is powered by a 3126 Cat motor producing 275hp and gobs of torque. The drive-line is tight. Runs and drives excellent. This truck received a level 4 maintenance service in 09-2018 by a retired motor pool sergeant . All hubs were taken apart and rebuilt with new seals, gas tank was removed and acid cleaned with all fuel lines, all fluids, filters, etc replaced
This is a rugged off-road EMP PROOF former military m1079 camper truck that will go anywhere you want it to. 1608 original miles! Yes! 1608 original miles. This truck is like new.
You will not believe how nice it rides!
Will run 58 mph and stop on a dime! the truck runs and drives perfect.
The cab and spare tire are air over hydraulic operated. No lifting the spare up or down. Has 2 trailer plugs, one 24v and the other 12v. All of the lights work perfectly. New tires are 395/85/20 with 100% tread! No, smells, noises, nothing. runs and drives perfect.
This truck is perfect for an off-road RV camper conversion, work truck, swat vehicle, mobile command station, parades, Zombie-apocalypse vehicle or just a toy to add to your collection.
