Tell me what surplus you are looking for, I will tell you if I have it...
Steel Soldiers is supported by:
MWMULES
88
DESOTO, KANSAS
Not MV but need a set of filters for the m50 protective(gas) mask, used is ok just need them for display.
Orionspath
Northern Virginia
Ammo Can Racks......
Are there in existence, a G.I. Issued, metal/aluminum ammo box "tray" that you know of that I could incorporate into a "rack" for these 40mm ammo cans? Would need two (2) of them for fabrication needs........Thanks. Pete
firefox
General
Berkeley CA
These are for an M54A2 as seen in my avatar.
End piece of the PTO driveshaft that has the hole for the shear pin.
Some idiot drilled an oversize hole in it and put in a steel pin.
So either I get a new piece or figure out how to beef up the hole to the right
size for the standard shear pin which I have plenty of.
I also need a set of the correct bolts to attach the winch extension. These are
evidently a little more special than just grade 8 bolts.
Thanks for any help on this.
Bruce
