The trail tells me what to remove
olly hondro
504
tucson AZ
blazer new doors.jpgPut the Blazer on a diet to compensate for the weight gain from D60 + 14BFF, locked both ends: Top, back seat, tailgate, pintle hitch, doors. Moved the batteries to behind the passenger seat on the floor (optimas x 2). Spare lies flat on the floor. Wheel wells cut using a M35A2 front fender as a template. Loooots of lessons learned over the last couple of years :)
olly hondro
504
tucson AZ
Thanks :) The doors are from a commercial source (PM me), very well engineered as the original hinges and latch are unchanged. Its bolt up.
The Blazer had a tendency to stand up on its rear wheels at step-like obstacles. After adjusting weight/CG, it doesn't do that anymore = good thing.
If I was restricted to only one modification, then it would be the front locker. That's what separates the herd into groups that can do technical trails and those who cannot. In my opinion, which is free ;)
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I have no cucv to put the doors on, don't get upset if I don't PM. I have a civillian2000 chevy with the 6.5, thats about as close as I'll get.
olly hondro
504
tucson AZ
Yes, Ridenby, I'll get some pix up.
Should I wait until the cab cage gets installed before gimpyrobb test drives it? :)
olly hondro
504
tucson AZ
Do not think that would work well here,too many mud holes,creeks,brush.
Yes, its OK here, I avoid mud like the plague: You could have twelve wheel drive and get stuck in mud :(
I saw pix elsewhere on this site where a fella got his 5-ton stuck in mud, so went to get his other 5-ton to pull it out, got both stuck. That was enough convincing for me.
As far as slinging stuff into the engine compartment goes, I travel veeerrry sloooowly. I budget one hour for each mile on the trail. IMG_2012.jpg
