TM's for the M39 Series 5-ton
Steel Soldiers is supported by:
Admin
3,519
n/a
Listed below are a number of the TM's for the 5 ton and up trucks. To save them to your computer, right click, select "save as"
LO9-2320-211-12.pdf
LO9-2320-211-12 Lubrication order for M39 Series 5-Ton truck.
TM9-2320-211-10.pdf
TM9-2320-211-10 Operator's Manual for 5 ton M39 series trucks with multifuel engines.
TM9-2320-211-10-1.pdf
TM9-2320-211-10-1 Operation, Installation and reference data Operator Level for 5-ton M39 series trucks.
TM9-2320-211-10-2.pdf
TM9-2320-211-10-2 Scheduled Maintenance Operator's level for 5-ton M39 series trucks.
TM9-2320-211-10-3.pdf
TM9-2320-211-10-3 Troubleshooting Operator Level for 5-ton M39 series trucks.
TM9-2320-211-10-4.pdf
TM9-2320-211-10-4 Maintenance Operator's Level for 5-ton M39 series trucks.
TM9-2320-211-20-1.pdf
TM9-2320-211-20-1 Scheduled maintenance organizational level 5 Ton M39 series trucks with multifuel engine. 1 of 3
2320-211-20-3-2.pdf
2320-211-20-3-2 Maintenance Organizational Level 5 Ton M39 series 6x6 trucks Vol. 3 of 3 part 2 of 2.
TM9-2320-211-20.pdf
TM9-2320-211-20 Maintenance manual Truck Chassis 5 ton M39 series.
TM9-2320-211-20P.pdf
TM9-2320-211-20P Organizational level Parts and special tool lists M39 Series 6x6 5 Ton.
TM9-2320-211-34-1.pdf
TM9-2320-211-34-1 Direct and general Support Troubleshooting M39 series 5 ton 6x6.
TM9-2320-211-34-2-1.pdf
TM9-2320-211-34-2-1 Direct and General Support Maintenance for M39 series 5 ton 6x6 Engine to rear axles 1 of 4.
TM9-2320-211-34-2-2.pdf
TM9-2320-211-34-2-2 Direct and General Support level M39 series 5 ton "Brakes through Body" 2 of 4.
TM9-2320-211-34-2-4.pdf
TM9-2320-211-34-2-4 Direct and General Support level M39 series 5 ton series body Access. & ref. 4 of 4.
TM9-8028.pdf
TM9-8028 Operational and Organizational Maintenance M39 series 5 ton truck all variants.(Include Gasolines)
TB-9-2300-426-20.pdf
TB-9-2300-426-20 Hydraulic and Air Hydraulic Brakes Preventative Maintenance.
TB43-0002-87.pdf
TB43-0002-87 Brake fluid replacement procedure.
TM9-3830-501.pdf
TM9-3830-501 Repair and Maintenance Gar Wood Winch w/ level winder Front 20,000# and Rear 45,000#.
gringeltaube
Staff Member
Montevideo/Uruguay
