- 1,392
- 170
- 63
- Frisco Texas
what size tire? Does it have 2 valve stems?Is it a HET wheel? I can't find any good images of HET wheels on Google, or maybe my Goo skills are weak.
MRAP is a whole bunch of different vehicles with no real connection between them other than they are mine resistant.The lugs look like they are quite far from the edge. Doesn't look like MRAP I see online. Looks like the bolt pattern is small.
You are correct about that; what you have there is an aluminum wheel with a std 10-on-11.25" bolt pattern and 8.66" pilot hole. Most MRAP wheels have the larger 335mm bolt circle, with the 281mm pilot hole.The lugs look like they are quite far from the edge. Doesn't look like MRAP I see online. Looks like the bolt pattern is small.
