- 10,228
- 6,029
- 113
- Camp Wood/LC, TX
What can happen with ignition coils is that the copper windings inside can have good continuity, but the insulation has broken down, allowing the high voltage to jump to ground inside. A multimeter does not have sufficient voltage to test for this breakdown. You would need an expensive instrument called a “megger”.
