Nightvision
- 0
- 0
- Elk Grove / California
Bigger tires ??!! If it's got 14.5R20s you have 43"+/- unloaded radius. It leaves about 4 inches between the rear tires. Bigger is not a safe option. Slinging 280lbs. at 50 mph will cause tires to expand another 1" + . I've seen mine do it on the dyno. When running @ full speed , gap is about 1.5" between rears.
If you just spent the 6$-8$k to purchase truck, it sounds like you got the money to burn, do it right - replace the transmission.
I'll have 6 speed kits ready in 3-6 months. I have 5 speed kits available now. They sell for 5$-6$K complete.
Here's your gear ratio's for the AT1545.
1st 3.45:1
2nd 2.25:1
3rd 1.41:1
4th 1.00:1
Reverse 5.02:1
Rockwell 2.5ton axel ratio 6.72:1 There is no know convertions for this axel.
Go to this link for drive train calculations.
http://www.f-body.org/gears/
JR
1st 3.45:1
2nd 2.25:1
3rd 1.41:1
4th 1.00:1
Reverse 5.02:1
JR
