- 1,954
- 402
- 68
- Culver City, CA
The emergency engine shutdown brass fuel valve had been leaking when under load on my truck and I finally got around to replacing it. Thanks to Cummins guru Will Wagner I was able to easily obtain, and at a decent nominal price, the valve. It appears to a better design than the original valve.
A very simple fix, it required about 10 mins. I used a 1/2" (fuel line), 5/8" (valve body), 7/16" (pull wire bolt) wrenches and a crescent wrench for removing the tachometer cable.
Here's a pic of the box for part number reference.
