M35A2 wheel spacers
Bloodmike
Hatfield pa
I've been having an issue with my driver side front tire rubbing my steering control arm. It's only a problem with right hand turns, but it seems to be chewing up my inner tread of the tire. I have done my fair share of digging tiring to to find a solution. Does anyone have this issue? And if so what have been the remedies, I am trying to track down some wheel spacers that will offset the wheel by 2 inches or so. Any help would be apprectiated.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Good luck. Most guys that use the 395 on stock rims have that issue. About the only thing you can do is cut the center out of a stock rim and use that disk as a spacer. It will bolt on like duals would. Spacer, thimbles, rim with tire, thimble nut. It is possible to weld 2 stock rims together to get the correct 10" wide rim, but It takes a lot of time to do it.
MWMULES
344
DESOTO, KANSAS
Mike how about a thread on your truck, looked at your album and all i can say is WOW!
gimpyrobb
27,785
747
Cincy Ohio
The problem he is having is the offset of the stock rims. As stated, the 135 rims would help with the rubbing issue, but not fix the fact that he is using rims too small for the tires.
