LEO/FD HMMWV Check List & Part Numbers
Gibberogill
Idaho
Here is my first post on S.S. I just summarized the above in a spreadsheet. Please correct and modify if necessary.
SYSTEMPART DESCRIPTIONMANUFACTURERPART NUMBER
Engine--filters
Air FilterFramCA8331
Fuel FilterKaydonA910428
Oil filtersACPF35
Champion Lab PH1218
FramHP4, PH13, PH 5
Mobil 1M1302
Motor CraftFL12
Purol30040, 34631, 35132
Wix 51060 (preferred), 51061
Engine--glow plugGlow plugsKascarAC 60 G
Wellman 24v (Diesel Rx)DRX00115
GMGM5614017
Engine--coolingHeater core 90 degree bendGates 27466
ThermostatDelco (180 degree)12T6D
Thermostat gasketFel Pro35271
Upper radiator hoseGates 22301
Engine--exhaustY pipe-to-manifold gasket (exhaust donut)Fel Pro60584 @ 2 each
Y pipe-to-mufflerFel Pro60718 @ 1 each
Engine--power steeringPower steering gearMaster Pro504-0107
AC Delco3600167
Engine--intake manifoldIntake manifold gasket 6.5 literNAPA, FelProMS 91585
BrakesFront brake caliperAL CardoneRight Front: 18-4182
AL CardoneLeft Front: 18-4281
Drivetrain--bearings and sealsAxle stub annular bearingGM9439608, 9411324
?P207K
Carrier outbearing set (left hand and right hand sides)TimkinLM603049, LM 603012
GM7451140
Carrier bearingSpicer 211415X
Output seal plain to flangeSKF544401-22
?CR0061
?6009472, 5579989
Pinion bearing set (large)GM7451155
?M802048, M802011
Pinion bearing set (small)?M88048, M88010
GMGM 7450984
Drivetrain--axlesAxle right frontGSPNCV82075 @ 28-9/16"
Axle left frontGSPNCV82074 @ 23-3/16"
Axle backGSPNCV83999 @ 26-1/2" (compressed)
Drivetrain--U-jointsU-joint frontSpicer 5-153X @ 3 each
U-joint rearSpicer 5-213X @ 2 each
Body/ChassisWindshield WipersAnco51-11
Autozone "duralast"11 inch
Windshield washer pumpAnco67-23
