Choosing The Right Dana 60 and 14 Bolt GM For Your Swap
nattieleather
134
Cleveland, OH
Those are stock fenders. Doing the axle swap doesn't make the front that much wider. The only problem with it is because of the spring perch is on the diff in order to make the axle line up centered on the truck you must do one thing or another. Either A: Bump the passingers side spring to the outside of the frame or B: shorten the drivers side axle housing. Again this isn't for width so much as it is form alignment.
