Not to over-simplify, but it almost seems as though the 12 and 24v systems on this truck could be considered separate and I should be able to add what I want to the 12v side and not affect the 24v side.
Nope. They are not two separate systems. The 24v system piggybacks on the 12v system. It's really two 12v systems,
but they are not separate. One of them is parked "on top" of the other to make 24v.
Let's see if I can make this diagram in ACII art:
+ 24v
+ 12v
That's two 12v batteries
in series. The negative terminal of the TOP battery connects to the positive terminal of the BOTTOM battery. That symbol at the bottom made of equal signs = represents the vehicle ground. There are +24 volts between the positive terminal of the TOP battery to vehicle ground. There are +12 volts between the positive terminal of the BOTTOM battery to vehicle ground. Oh, that's the same thing as saying there are +12 volts between the negative terminal of the TOP battery and vehicle ground. These two locations are electrically equal - the negative terminal of the top battery and the positive terminal of the bottom battery are connected.
You don't have two separate systems. You have ONE system, with two alternators, and we tap between the two batteries to get 12v for running most of the vehicle's systems (lights, radios, heater, etc.).
We take juice from the positive terminal of the TOP battery to get 24v for the starter (and the glow plugs, if it's still in stock configuration).
The BOTTOM battery is battery 1, the FRONT battery. His positive terminal is where we get our +12v stuff.
The TOP battery is battery 2, the REAR battery. His positive terminal is where we get our +24v stuff.
Clear as mud?
Hey, just be glad these things aren't positive ground. That gets REALLY fun when you are trying to add +12v accessories!
![Mr. Green :mrgreen: :mrgreen:](https://www.steelsoldiers.com/images/smilies/icon_mrgreen.gif)
