Air Bag rear suspension
Bill in pa
40
homer city pa
Im starting to bob my 813a1 truck next week.
All the parts for the project right around $1500 shipped.
Im wondering any one ever consider air bags instead of springs.
Seams like it should be straight forward.
Also on a different note. My turn signals all quit. they go bright when put on but don't blink.
New Flasher box Needed?
zxmedic
Canada
Try opening the turn signal switch mine had one of the point contacts stuck together unstuck it cleaned them up with some fine sandpaper worked great after .
wreckerman893
Possum Connoisseur
15,647
2,141
:tigger:
There were some 900 series 5 ton prototypes at Camp Shelby, MS that had air bags but all the raw frames got scrapped. One or two of the finished trucks made it out of the gates. CSMDavis may know where one of them is.
You could go to a truck junk yard and get a bag setup off of a commercial rig and go that route.
quickfarms
25
Orange Junction, CA
On a bobbed truck it would work well and you could use any commercial truck suspension.
If you get a suspension from a wrecking yard, plan on replacing the bags and get a frame clip so you can use the old frame as a drilling template.
On a three axle truck the standard civilian truck suspension is not that great. There are air ride walking beam suspensions available that are great off-road but they are not that common and hence expensive from the wrecking yard, or not available used.
Artisan
229
CDA Idaho
A friend of mine is making a crewcab 5ton rear air ride truck.
The rough cab is done, dual round headlights installed and
lots of other fun. The rear is mocked up. It WILL get done
eventually. He is doing a great job. If anything happens soon
I will ask if I can take pics
Sub'd
Motiracer38
Santa Clarita, CA
Sub'd
I met your friend the other day, stopped by to see if he was selling the framerails off the stripped truck. He's a very ambitous guy that should do a pretty good job of installing an air ride system. It sounded like he was going to use big heims on a 4 link instead of the commercial style rubber bushings in a trailing arm. I'm interested in both styles as my truck will be riding on air once I get around to cutting into it.
Bill in pa
40
homer city pa
what suspension did you use. I got a complete set up from a guy for 500 + air bags. How did you determine where to place the axle.
Im thinking of leaving the front axle in the same place and just drop the back one
panzerwillie
311
miami florida
axle
We where going to use a front drive shaft to set the single axle but could not find one near us, so we extended the tube on the 62" operating from yoke to yoke hope this helps..
20140531_144438-1.jpg20140606_141443.jpg20140531_123310-1.jpg20140531_100924-1.jpg20140528_111204.jpg
Bill in pa
40
homer city pa
good morning.
when your air suspension was completed. did you end up with the axle on top of the springs or under the springs?
I have mine under then springs. this has the top of the frame even with the top of the tire, with only about 5" for the air bag which don't fit.
Im thinking the axle needs to be on top of the springs. thus the air bags will fit and more and be able to get 12" from the top of axle to the frame same as the front. thanks for any help.
panzerwillie
311
miami florida
My is under the spring you can use trailer airbags which are shorter or mount them in the inside of the frame like i did, need to fab top support and lower support mounts...
Bill in pa
40
homer city pa
Mine is all done except for the torque bar. Need a idea for torque bare to go from the frame to the axle, to hold axle side to side. Send me a email to binnalljr@yahoo if you want and I can send pictures of mine. Took me 2 weeks of evenings and weekends by myself.
Csm Davis
406
Hattiesburg, Mississippi
good morning.
Don't forget that you can also move you airbags around to get the suspension to work how you like it.
