Mounting a spare under my M1102
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
Finally got around to getting the spare mounted. The winch came off a M1076 pls trailer, the bar you turn was about 1.5 ft to long and had a 1.5 in. drive head on the end. I cut the bar to length, drilled and tapped the end for a 1/2 in. bolt(I wanted the 3/4 in. head) then plug welded the bolt in place. The pillow block mounted to the cross member is original to the M1076 design and didn't move more than 1/16th in. on the bar when mounted on the M1102. I couldn't have asked for a more perfect fit. Now for the pics!IMG_20141228_143310486_HDR.jpgIMG_20141228_143242814_HDR.jpgIMG_20141228_143446252_HDR.jpgIMG_20141228_143256503_HDR.jpgIMG_20141228_143332723_HDR.jpgIMG_20141228_143622205.jpg
5,161
Thank you sir! I happened to be looking at my trailer today and a spare take off wheel I had laying around and thinking about this!
bookpile
PA
Hi,
That looks great. I've been looking for some ideas. Where did you get the winch from. Is it for a spare tire on the trailer as well, or for something else. Do you know a NSN?
Tinstar
2,569
East of Edmond, Oklahoma
If the trailer only sees on-road duty, that's a very good idea.
I like it.
Off-road, the tire would catch/hang on stuff very easily.
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
The winch was off a M1076 pls trailer, it was the spare tire winch on said trailer, no I don't have a nsn.
Hi,
John Galt
Fort Worth, TX
Nice install. What does that do to the tongue weight? I used to put a spare tire in the back of tub so I could stand the trailer up on back end (to work on wiring) and it would stay on its own.
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
I weigh about 180lbs and with the tailgate down I can very carefully still climb into the trailer, but it's right at the tipping point. It makes lifting the tongue on and off the pintle hitch easy.
Sent from my XT1080 using Tapatalk
