rivercreek
- 1
- 18
- Berryville, VA
So, I thought I would share the result of using low range reverse on a 900 series truck, for those of you who are not clear as to exactly
why this is a bad idea...
I'll give a short background on exactly what caused this catastrophic failure: We use a number of 900 series trucks for snow removal - they are contracted with VDOT for the winter season. Since they sit all summer, inevitably some of the brakes are seized up by October, requiring a few strategic smacks on the brake drums with a 4lb hammer to release. I had a buddy over helping me with pre-season inspection/maintenance a few days ago. Assuming he was checking fluids, tires, etc., I didn't worry too much about what exactly he was doing outside in the back yard until I heard a huge BANG. Long story short, he had fired up the truck, pulled the t-case down into low range and apparently was attempting to break the shoes loose by rocking it back and forth. Physics 101: When the wheels won't spin, the power must go SOMEWHERE! This pain in the @$$ wasn't completely bad, however - there is a bright side. We've discovered a valuable time-saving maintenance tip that I am happy to share with everyone: This is by FAR the quickest and easiest way I've ever seen to drain the transfer case. Much quicker, easier and faster than having to climb up under the truck with a wrench and a shop rag and a drain pan and all that hassle. This method I will call the "Mark Technique" in honor of my buddy Mark (the guy who did it).
why this is a bad idea... I'll give a short background on exactly what caused this catastrophic failure: We use a number of 900 series trucks for snow removal - they are contracted with VDOT for the winter season. Since they sit all summer, inevitably some of the brakes are seized up by October, requiring a few strategic smacks on the brake drums with a 4lb hammer to release. I had a buddy over helping me with pre-season inspection/maintenance a few days ago. Assuming he was checking fluids, tires, etc., I didn't worry too much about what exactly he was doing outside in the back yard until I heard a huge BANG. Long story short, he had fired up the truck, pulled the t-case down into low range and apparently was attempting to break the shoes loose by rocking it back and forth. Physics 101: When the wheels won't spin, the power must go SOMEWHERE! This pain in the @$$ wasn't completely bad, however - there is a bright side. We've discovered a valuable time-saving maintenance tip that I am happy to share with everyone: This is by FAR the quickest and easiest way I've ever seen to drain the transfer case. Much quicker, easier and faster than having to climb up under the truck with a wrench and a shop rag and a drain pan and all that hassle. This method I will call the "Mark Technique" in honor of my buddy Mark (the guy who did it).
