PTO output seal
gringeltaube
Staff Member
2,292
Montevideo/Uruguay
Parts Cross Reference: position #8 under Resources, FYI.
I already checked it out, sorry, that seal is not listed yet.
Aren't there any places where you can order a seal to given dimensions in height and shaft & housing diameters?
G.
Stretch44875
Super Jr. Moderator
Tiro, Ohio
Will that PTO bolt to the back of a deuce PTO for a dual output unit(front and rear)?
Pappa-G
Central, MI
I got one from Memphis Equipment, it cost around $13 if I remember right. Mine must have been leaking for a while. When I got the truck from DRMO the trans was 2 gallons low on fliud! but it took only minutes to pull and swap the seal so it was an easy fix.
Good Luck!
madsam
M
In the other thread, some one said they are the same. But there was a question about output shaft..
gringeltaube
Staff Member
2,292
Montevideo/Uruguay
Madsam: that kit does not list the required oil seal for the rear output shaft. From the manual it is part# 7061271 (NSN 5330-00-559-8733).
Also the position shown for seal#500038 is confusing..., better check with Mike, I think his kit is complete just for the WN-7-28, not the dual output WND-7-28.
Rizzo: only the rear output section is the same for both and so they share above mentioned oil seal. Let me see tomorrow if there is any difference in diameter of the front output shaft or bearing cap so that the front oil seal would differ too.
G.
rizzo
Port Huron, MI
G.
thank you
gringeltaube
Staff Member
2,292
Montevideo/Uruguay
gringeltaube said:
......if there is any difference in diameter of the front output shaft or bearing cap so that the front oil seal would differ too. G.
OK, just took both appart, measured everything and confirmed that bearing caps are identical. Shafts differ in lenght but diameter is exactly the same: 1 1/4" . Seal specs would be 2 1/16" x 1 1/4" x h 1/2", (double lip)
So far I can asure that all seals and boots are good for both PTOs.
G.
rizzo
Port Huron, MI
G.
I'm going to talk to my hydraulic friend today. He is also a power wagon buff. He might be able to order one.
thanks for the comparison.
gringeltaube
Staff Member
2,292
Montevideo/Uruguay
..... and for the sake of completeness let me add dimensions for the questioned rear facing output seal: 2 1/6” x 7/8” x 11/16” cavity depth.
More than enough room for a nice double lip seal or two smaller single lip, with the outer one installed facing outward.
G.
gringeltaube
Staff Member
2,292
Montevideo/Uruguay
Rocco said:
Does anyone have the civilian cross reference number
for the output seal? The military part number is 60206-CI
This part goes on to the PTO for the 5 ton dump truck.
Possibly you already got one? Just pulled one out, stamped JC-087-2050-12. Seems to be original, although I don't like it, it's a single lip 3/8" height. (see my previous post)
