Lube in trailer plug?
mhb285
Paso Robles, Calif.
Can anyone tell me what type of grease or lube is used in the trailer plug? It also looks like the same stuff thats used in the slave plug. I want to get some and I'm sure what type to use...
Mike
Flea
10
Northeast TN
Di-electric grease is what you want. It will seal out some of the moisture that corrodes terminals, while promoting conductivity at the same time.
stampy
22
Henderson. NC
Also works great on fuses...battery connections .. any electrical connection that you need to make sure stays corrosion free and working. I love that stuff. It has solved lots of my diesel benz problems.:-D:-D
uoa
OSU, OK
My NAPA has big tubes, about the size of a normal tube of toothpaste but fatter and shorter. It was in the big truck section and cheaper than the same stuff in the car section in a smaller tube. Just a helpful hint.
Elwenil
40
Covington, VA
Dielectric grease is great stuff. Squirt some in a connector or socket and never worry about it again. I've scrapped vehicles that I leaned the sockets and filled them with grease years before and they were all still clean and working perfectly. I don't like using WD-40 as it can damage a lot of plastics used in electronics. If I need a spray, I use spray silicone.
emmado22
163
Mid Hudson Valley NY
Dielectric grease makes the rubber military electrical connectors got together and slide apart with ease.. I put it on every connection I take apart...
andyindy
Rising Sun Indiana
Ejc
I use EJC (electric joint compound) ,trade name. Works great, but unlike a wheel bearing, it just takes a little and it really helps. It is also for dissimilar conductors at the same terminal, ie copper and alumnium, ect.
Andy................
dabtl
Denton, Texas
WD40 will evaporate causing rust. Never use it for much other than as a temporary penetrating oil.
It also works well to displace moisture.
But, as long term lubricant it is not good.
TBigLug
Stockbridge, MI
It keeps corrosion from forming, but does not actually CONDUCT electricity.....
Always use di-electric grease. Regular gease can conduct electricity sometimes (metal flakes or something in the compound). Regular grease works on batteriews where your sealing single conductors (ie. no risk of electricity jumping). I've used di-electric for years. Never had a problem.
