sermis
- 17
- 38
- Temple, TX
Well I took on the task of a M944A1 recover for reb87 from Ft. Hood. The pic’s on GL showed drivers fender damage. The GL guy said that they used a forklift to unload and we assumed the damage was caused by that. I get there and discover the damage was from a front end wreck. Kind of looks like a tow bar accident. Well we scoured the lot and found a couple bolts to put into the drivers side bumper on the bottom. I could not get one of the ¾” pin back into the tow bar due to the bumper being twisted so I used a line up bar and black tape to hold it in. The bumper and brackets were loose. My neighbor went with me so I had him ride in the truck and steer just incase. Hooked up the air lines and the brakes released. Pulled it off of GL’s lot and checked fluids and away we went at a land speed record of 30 down hill. I can saw it out weighed my deuce by 20,000 and it was all the little truck could do to pull. About half way home the front right brake started getting hot. Discovered that the emergency and service line are crossed on the front of the truck. Reconnected the hoses and it would only build 60 psi. made it home. I have a tight turn in front of my barn and that is where the bumper let go the rest of the way. With only two bolts on each side I guess we were lucky to make it this far.
