TM's for the Deuce
Admin
3,139
n/a
Listed below are a number of the TM's for the M35 trucks. To save them to your computer, right click, select "save as".
GTA-9-1-1851-8.pdf M35 complete diagram of with descriptions of all components.
LO9-2320-209-12-1.pdf
LO9-2320-209-12-1 Lubrication Order for the M35 series.
TM9-2320-209-10-1.pdf
TM9-2320-209-10-1 Operation, Installation and Reference data for the M35 series, Operator Level.
TM9-2320-209-10-2.pdf
TM9-2320-209-10-2 Scheduled Maintenance Operator level M35 Multifuel.
TM9-2320-209-10-3.pdf
TM9-2320-209-10-3 Troubleshooting Operator level M35 Multifuel.
TM9-2320-209-10-4.pdf
TM9-2320-209-10-4 Maintenance Operator Level M35 Multifuel.
TM9-2320-209-20-1.pdf
TM9-2320-209-20-1 Scheduled maintenance organizational level M44 series 2-1/2 ton trucks.
TM9-2320-209-20-2-1.pdf
TM9-2320-209-20-2-1 Organization level - Troubleshooting Multifuel M35 Part 1 of 2.
TM9-2320-209-20-2-2.pdf
TM9-2320-209-20-2-2 Organization level - Troubleshooting Multifuel M35 Part 2 of 2.
TM9-2320-209-20-3-1.pdf
TM9-2320-209-20-3-1 Organization level - Maintenance M35 Multifuel Part 1 of 4.
TM9-2320-209-20-3-2.pdf
TM9-2320-209-20-3-2 Organization level - Maintenance M35 Multifuel Part 2 of 4.
TM9-2320-209-20-3-3.pdf
TM9-2320-209-20-3-3 Organization level - Maintenance M35 Multifuel Part 3 of 4.
TM9-2320-209-20-3-4.pdf
TM9-2320-209-20-3-4 Organization level - Maintenance M35 Multifuel Part 4 of 4.
TM9-2320-209-20P.pdf
TM9-2320-209-20P Organization level - Maintenance M35 Multifuel repair parts and special tools.
TM9-2320-209-34-1.pdf
TM9-2320-209-34-1 Troubleshooting Direct and General Support Levels.
TM9-2320-209-34-2-1.pdf
TM9-2320-209-34-2-1 Maintenance Direct Support and General Support M35 Multifuel 1 of 3.
TM9-2320-209-34-2-2.pdf
TM9-2320-209-34-2-2 Maintenance Direct Support and General Support M35 Multifuel 2 of 3.
TM9-2320-209-34-2-3.pdf
TM9-2320-209-34-2-3 Maintenance Direct Support and General Support M35 Multifuel 3 of 3.
TM9-2320-209-34P.pdf
TM9-2320-209-34P Direct and General Maintenance and Support Parts and Special tools.
TM9-2320-361-20.pdf
TM9-2320-361-20 Technical Manual and Unit Maintenance. (Later Edition TM)
TM9-2320-361-20P.pdf
TM9-2320-361-20P Unit Level Maintenance M35 Multifuel Repair parts and special tools. (Oct 1993)
TM9-2320-361-24-1.pdf
TM9-2320-361-24-1 Field and Sustainment Maintenance 1 of 2. (Later Edition TM)
TM9-2320-361-24-2.pdf
TM9-2320-361-24-2 Field and Sustainment Maintenance 2 of 2. (Later Edition TM)
TM9-2320-361-24P.pdf
TM9-2320-361-24P, pub. Aug 2006, supersedes TM 9-2320-361-20P, 25 Oct 93, and TM 9-2320-361-34P, 30 July 93
TM9-2320-361-34.pdf
TM9-2320-361-34 Direct Support and General Support Maintenance M35 Multifuel. (Later Edition TM)
LO9-2320-386-12.pdf
LO9-2320-386-12 Lubrication order for the M35A3.
TM9-2320-386-10-HR.pdf
TM9-2320-386-10-HR Hand Receipt for M35A3
TM9-2320-386-10.pdf
TM9-2320-386-10 Operator manual for the M35A3.
TM9-2320-386-24-1-1.pdf
TM9-2320-386-24-1-1 Unit, Direct and General Support Maintenance TM for the M35A3 1 of 2.
TM9-2320-386-24-1-2.pdf
TM9-2320-386-24-1-2 Unit, Direct and General Support Maintenance TM for the M35A3 2 of 2.
TM9-2320-386-24P.pdf
TM9-2320-386-24P Unit, Direct and General Support Parts and Special Tools lists for M35A3.
******************* Individual Component Manuals **********************
TM9-2520-246-34.pdf
TM9-2520-246-34 Direct Support and General Support Maintenance manual for Transmission 3052.
TM9-2520-246-34-1.pdf
TM9-2520-246-34-1 Direct Support and General Support Maintenance manual for Transmission 3053A.
TM9-2520-246-34P.pdf
TM9-2520-246-34P Direct Support and General Support Maintenance Transmissions, Transfers, PTO's.
TM9-2815-210-34-1.pdf
TM9-2815-210-34-1 Troubleshooting Direct Support and General Support levels Engine 465 Multifuel.
TM9-2815-210-34-2-1.pdf
TM9-2815-210-34-2-1 Maintenance Direct Support and General Support levels Engine Assembly Multifuel 1 of 2.
TM9-2815-210-34-2-2.pdf
TM9-2815-210-34-2-2 Maintenance Direct Support and General Support levels Engine Assembly Multifuel 2 of 2.
TM9-2815-210-34P.pdf
TM9-2815-210-34P Parts and special tool lists Direct Support and General Support levels Engine Assembly Multifuel.
TM9-2815-204-35.pdf
TM9-2815-204-35 Field and Depot maintenance for Continental LDS 427-2 Turbo supercharged Diesel Engine.
TM9-2815-204-34P.pdf
TM9-2815-204-34P Parts and Special tool lists for Diesel LDS 427-2.
TM9-2910-226-34.pdf
TM9-2910-226-34 Direct and General Support Maintenance (Including Repair parts and special tools lists) For Pump, Fuel metering and distributing assembly: 2910-178-1185, 2910-759-5410, 2910-908-6320, 2910-968-6317 & 2910-116-8241.
TM9-2990-201-45.pdf
TM9-2990-201-45 General Support and Depot Maintenance for Schwitzer Turbocharger, engine assembly including parts & special tools list for models: 4-456, 4D-554, 4D-454C, 4LE-354, 4LE-456
TM9-3830-206-34p.pdf
TM9-3830-206-34p Direct and General Support repair parts lists Winch assembly w/ or w/o level winder.
************************* Miscellaneous Manuals *****************************
AMBAC PSB6 Injection Pump Reference
Service Parts List and Calibration Specifications for all American Bosch Model PSB 6A Injection Pumps. (1972)
m35a2_camo.pdf
3 color NATO camo pattern for the M35A2 M35A2C.
TB43-0147.pdf
TB43-0147 Color Markings and Camouflage Patterns for Military Equipment (ca. 1975).
TB43-0209.pdf
TB43-0209 Color and Camouflage Markings of Military Eq. and Construction Equipment (ca. 1990).
TB-9-2300-426-20.pdf TB-9-2300-426-20 Hydraulic and Air Hydraulic Brakes preventive maintenance.
TB43-0002-87.pdf TB43-0002-87 Brake fluid replacement procedure.
PSMultifuelOperators.pdf
PS Magazine is the Army's preventive maintenance monthly.
PS Multifuel Warm-up.pdf
PS Magazine is the Army's article covering proper warm up of the multifuel engine.
