Help with an air conditioner.. what is it?
n3uka
Beltsville, MD
I recently picked up a:
Air Conditioner Horizontal Compact, 9000 BTU/HR
208 volts, 3 phase, 60 HZ
NSN 4120-01-193-4998
Any help on what it was meant for, pubs on it and
where to find the missing components if I were to try and
set it up. Looks like it is missing the controller?
Thanks in advance,
Dave
derby
10
S.E. MI.
I don't know anything about it,but could it be for an expandable shop or command center ? 208v 3 phase?will be hard to hook on houshold power.you will need a converter.the missing controler could be a remote cable connector.just a guess
ida34
36
Dexter, MI
Mobile field hospitals use air conditioners in the inflatable tent complexes they use. This may be one of those. This is a guess at best.
G744
4,120
Hidden Valley, Az
Looks to be an end item from the TSC-60 radio shelter, S250 sort-of. Had it mounted on a set of slides so you could push it in when transporting.
Had 6 of them some time ago. Each also had a Collins HF-80 10kW transmitter in it.
dg
gmayor
St. Robert, MO
Google "Airtacs air conditioner", it is about fourth one listed, has exact pictures and specs. says it is USMC for multiple applications, 3/4 ton etc. Sounds like pretty good unit.
