UT Air Filter Gasket for Military MEP-531A / 501A Diesel Generator
Valence
612
Davis County, UT
This rubberized gasket is not a generic “replacement”, but the exact, genuine proper material manufactured to specification in the USA. One side has adhesive to secure the gasket in place.
Quantity 2 air filter gaskets are needed per generator, one between the air filter and generator and the other between the air filter and outer plastic air cleaner housing.
$5.95 each (sold individually) + shipping, multiple available
Features:
  • NSN: 5330-01-472-5601
  • Part Number (P/N): 95-8053-1
    • Fits Dewey and Mechron Military MEP-531A (120 VAC) and MEP-501A (28 VDC) 2kW Yanmar L48AE Diesel Generators
  • Manufactured January 2024
  • Single adhesive side
  • OD: 3-5/8″
  • ID: 2-3/4″
  • 7/16″ material width x 1/8″ thick
  • Genuine Mil-Spec
This is item #3 as listed in the Technical Manual (TM) 9-6115-673-13&P “Operator and Field Maintenance Manual (Including repair Parts and Special Tools List)” on Figure 8 on page 0124-2 (PDF Page #488 ).
Notes: Care should be taken when peeling off the paper backing to expose the adhesive, or else it may be possible to strip the adhesive from the gasket. For easier maintenance, the gasket can be adhered directly to the air filter, but new gaskets will be needed when the air filter is changed.
Made in USA.
Located in Kaysville, UT.
mep531a_air_filter_gasket_02.jpg mep531a_air_filter_gasket_03.jpg mep531a_air_filter_gasket_04.jpg
mep531a_air_filter_gasket_05.jpg mep531a_air_filter_gasket_06.jpg mep531a_air_filter_gasket_07.jpg mep531a_air_filter_gasket_08.jpg
mep531a_air_filter_gasket_09.png mep531a_air_filter_gasket_010.png mep531a_air_filter_gasket_11.png
