UT Bow Storage Straps for Military Cargo Trucks
Valence
613
Davis County, UT
I make these myself.
$45.00 each + shipping
Located in Kaysville, UT
I only have a limited quantity available at this time (due to the cost of the replacement round rod mounting buckle). If these sell I can have more made.
These straps are designed to replace the oft missing, damaged, or sun rotted straps on the bent rod for under-bed bow storage on military cargo trucks such as the M35A2C (deuce and a half with drop-down bed sides), or any of the M39, M809 and M939 series cargo trucks so equipped trucks (and possibly others). Keep your cargo bows securely stowed until needed! These straps are not intended as life safety devices.
Replaces the following parts:
  • Buckle end: NSN 5340-00-930-2716 (5340009302716), Part Number: 10937881
  • Tail end: NSN 5340-00-930-2717 (5340009302717), Part Number: 10937882
Straps and buckles only, no bent rods or mounting hardware included.
Features:
  • Set of 2 pair (4 straps total).
    • Each pair consists of an 8" (~20.5cm) long strap with an alligator buckle and a 15.5" (39.5 cm) long "tail" strap with brass tip.
    • Note: The buckle with the round hole is meant to fit 1/2″ (~13mm) diameter rods.
  • 1″ (25 mm) wide webbing.
    • MIL-W-4088: Olive Drab (OD7), Camo Green 483, Coyote, Foliage, Red, Black
      • Nylon
      • Type XVII, ~0.05″ (~1.4 mm) thick, 2500 lb (~1134 kg) breaking strength webbing, resin treated for abrasion resistance.
    • Repurposed Vintage mil-spec Dark Green Cotton
      • Please note, the Dark Green Cotton was unstitched from NOS webbing gear so it will show signs of previous stitching and it has a little stretch to it.
      • 100% Cotton
      • ~0.10″ (2.5 mm) thick
      • Mildew resistant & water repellent treated.
    • MIL-W-43638: Vintage Natural color Cotton
      • 85% Cotton & 15% Fortisan
      • Type I, ~0.07″ (approx. 1.8 mm) thick, 600 lb (~272 kg) minimum breaking strength, Type I
      • Low stretch
  • My own designed reproduction bent rod mounting steel buckle with flat black powder coating.
  • Black coated, solid brass tip, genuine mil-spec, meets MS51926B-3.
  • Mil-spec spring buckle clamp, genuine mil-spec, meets MS51929A-2.
  • Heavy, visible outdoor polyester or nylon stitching, UV resistant, anti-wick.
Made in the U.S.A.
NOTE: I do not certify nor guarantee assembled breaking strength. Webbing specifications provided for informational use only. Not intended as seat belts or life safety devices.
bow_storage_straps_01.jpg bow_storage_straps_02.jpg bow_storage_straps_03.jpg
For best performance, please ensure your strap is installed properly!
