FLU419 4x4 won't go into 4x4
Goathairs
Wilmington, NC
Hey guys, first post here. I've done some digging but couldn't find this specific issue. The air system builds pressure just fine but doesn't seem to be engaging the 4x4 or locker. When you turn the switch back to RWD there is a faint hiss releasing some pressure. Where is the best place to start looking?
There is also a slow leak which sounds like it's at the gauge behind the dash. What is the best way to get that out to fix it??
Thanks!
BELinNC
90
White Oak, NC
Hi over there in Wilmington. I am an hour or so away near Elizabethtown, NC. Glad to have another SEE owner around. My truck has the exact same issue. I have plenty of air pressure, but my truck must have sat for so long that the actuator solenoid seems to be frozen and will not move the lever. i have soaked everything with penetrating oil, but no luck with that. Plenty of hissing and air noise. As a temporary measure I have been able to manually move the lever with a crow bar. For most of my needs around my mostly flat property 2wd is enough, but I want to fix it properly
Goathairs
Wilmington, NC
Hey bud, FayetteNam! Could you snap a pic of what I'm looking for?
