Finally got back to the restoration bike today. I’ve been building a few other non-Marine Corps bikes. The electrical had the most issues. Prior to starting Bike 6’s restoration it wouldn't even attempt to start and none of the lights worked.
I finally got the headlight and tail lights to function. I noticed the brake light wasn't coming on. I just swapped out the bulb and problem solved. The rear blackout light, rear blackout light brake light, and front black out light all function.
Some people mistakenly believe that it illuminates (light the regular headlight) so that the rider can use Night Vision to ride. It actually just puts out enough light so that others wearing night vision goggles can see the rider. The rear has a functioning blackout light break light so that those following the rider can see when they are slowing down. See the videos below if your interested in how they function.
Rear Blackout Light
Front Blackout Light
Nothing was happening when I hit the start button. I’ve found that the clutch safety switch is usually the issue. Most of the time you can clean the brass connections on the bottom of the switch. I’ve also had to replace one since it was broken. I tested this by making a jumper on the harness side where it plugs in. Then it attempted to crank and it fired no problem. Once I disassembled the switch I noticed that the top clutch metal portion wasn't sticking out as much as it should. Upon disassembly I saw that it was missing the spring. You can see in the picture below how much higher the version with the spring is. Swapped that portion out and now the bike will crank.
![1.JPG 1.JPG](https://www.steelsoldiers.com/data/attachments/555/555462-3403402731c3fced13e6fee4715acc1c.jpg)
I was getting ready to start it up using my testing fuel bottle but the battery didn't have enough juice to really crank it over. I’m charging the battery now and will try again later in the week. Other issues when starting the bike for the first time could be an issue with the carb (I rebuilt it), no spark (I tested and its good), and I moved the choke from the handle bars to the carb itself. I use the Stead Engineering choke. Sometimes the spring is a bit tight.
I also tested the fan by removing the wire that plugs into the lower portion of the radiator and grounding it to the engine block. Then turn the key to “ON” and the fan should kick on.
