- 1,960
- 216
- 63
- Arizona
Sure!Awesome pics, keep them coming!
The air filter, out for cleaning. Note the coke can and 5 gallon bucket for size reference. I think almost every other air filter I have could fit easily inside of this one.
![het-51.jpg het-51.jpg](https://www.steelsoldiers.com/data/attachments/319/319170-a71bb0a6b258dba837b0a2d8eb6d6e68.jpg)
The air box where the filter lives.
![het-52.jpg het-52.jpg](https://www.steelsoldiers.com/data/attachments/319/319169-6adf7479b9642db045df50f6e7114f2e.jpg)
The power steering reservoir. Note the coke can for reference and the size of the lines coming from it.
![het-53.jpg het-53.jpg](https://www.steelsoldiers.com/data/attachments/319/319168-4fbb1b6129b652e467f952f1d5236f4a.jpg)
The various circuit breakers inside the cab.
![het-54.jpg het-54.jpg](https://www.steelsoldiers.com/data/attachments/319/319167-2b3da9bfb8708548f824fe6075aa3430.jpg)
A shot rearward from under the front axle. You can see the very large transfer case as well as all 5 gigantic air tanks.
![het-55.jpg het-55.jpg](https://www.steelsoldiers.com/data/attachments/319/319166-8d52cc37a58c59d4e6341d5c45bb701b.jpg)
The #2 axle (1st of the rear tridem) You can see how the air brake chambers are above the axles to increase ground clearance.
![het-57.jpg het-57.jpg](https://www.steelsoldiers.com/data/attachments/319/319164-745aa2b6fb4d313ed6a244ffb1046413.jpg)
Here you can see the massive transfer case to #2 axle drive shaft as well as the very large trailing arms.
![het-56.jpg het-56.jpg](https://www.steelsoldiers.com/data/attachments/319/319165-ac3fe775f147703178ee572e6dcee86c.jpg)
