saddamsnightmare
- 80
- 48
- Abilene, Texas
February 13th, 2014.![shrugs :shrugs: :shrugs:](https://www.steelsoldiers.com/images/smilies/confused1.gif)
Gentlemen:
The last couple of cold snaps have revealed an odd behavior trait on my 1963 Swiss Cargo Unimog with pertronix ignition and electric fuel pump set up. At zero degrees F or below, the truck will crank, but will not fire, and within a very few seconds she will flood out with the choke applied. She will not start at anywhere near that low unless the choke is applied, and what I am thinking is that between the oil bath air cleaner and the low temperature, the carburetor is not vaporizing the gas enough to allow the truck to fire it.
This truck sits outside, unprotected from the wind or the weather (it's much too tall for my garage), and as additional information, one starting battery is from 2008 and one is from 2010. When the temperature reaches four or five degrees above zero, she will fire and start with some small difficulty (rough running for the first half minute or so). When she refused to start at -10*F, the solution was to apply for 15 or twenty minutes a 250W worklight in the cab to warm the carburetor, and then she fired right off.
Did M-B ever make a block or cooling system heater for the S404.114's? I have seen some attempts to apply immersion heaters to the block, but that requires one of the freeze plates to be modified to take a block heater. How does M-B address this situation on the S406/408/412 and U1300L's when they have diesels (as the S404.114 seemed to be mostly gas engine trucks)?
Hopefully Wolf Dose will see this and add something to the discussion, as he does seem to be conversant with the S404.114 series...
Gentlemen:
