Stop water on the floor 2 man set up
hummer4x4guy
Lansing, Mi
Guys I just got in the following AMG parts today to work on solving the issue of rain water from flooding the front of the truck. Part #'s are 5938744A for the aluminum bracket piece and 5939988 for the "seal-cargo Flr/back pan.
My plans are to prime and paint it and attach directly to the bulkhead. If you have the front tie downs installed this can slip under those and the bulkhead will still bolt in. If this setup keeps water out enough without rivits or bolts I'll just run it like that. To each their own if this is a problem for your truck and rain. uploadfromtaptalk1430169235082.jpg
GMVguy
22
Utah
My plans are to prime and paint it and attach directly to the bulkhead. If you have the front tie downs installed this can slip under those and the bulkhead will still bolt in. If this setup keeps water out enough without rivits or bolts I'll just run it like that. To each their own if this is a problem for your truck and rain. View attachment 556705
Cool! Will these parts work for the 4-man bulkhead setup as well?
hummer4x4guy
Lansing, Mi
Mlacek, on 2nd look you would need two brackets and two seals or neoprene seal of some type on the bottom. The seal that is designed for it doesn't stick on its essentially a round rope kinda seal. I'll post some photos later when I get home to show the underside.
hummer4x4guy
Lansing, Mi
Here is a photo of the underside of the bracket and the seal that is designed to work with it. If ya need two side by side it would make sense to cut the brackets in the middle on both ends that would touch to remove the small section which doesn't have the grove to accept the seal to sit under it
GMVguy
22
Utah
Excellent - thanks!
whistlepig
big branch tn
Curtain to floor sealing
Looking for ideas to keep the draft out on my 2 man soft top rear curtain. I can't be the only one that ever tried to address the situation. Besides going with an artic top kit or an application of duct tape how do you military guys or anybody for that matter ,seal up the draft?
