- 2,136
- 613
- Davis County, UT
It's not as dramatic as it sounds, but the seller did say he had considered just straight up scrapping it, but thought he'd try selling it first. Hey, in Utah with the high Boy Scout population, it was a logical move. However, I want it for my own camping and not for the Boy Scouts.
Though, honestly, I can't keep the MVs out of my drive way. I keep adding to it!
Data Plate says:
CORPS OF ENGINEERS, U.S. ARMY
National Stock Number (N.S.N.): 2510-649-8384 (if you want to look this up online try adding a couple zeros for the second set of digits "2510-00-649-8384")
Nomenclature (NOM.): Body, Cargo TOOL MOUNTING
ENG 7&8
MAKE: METRO ENG & MFG
Model (MOD.): BCTM (if there's more, it's illegible)
Inspection (INSP.): (a mostly illegible stamp)
Serial (SER.): 533
Manufacture Date (MFD.): Nov 1960
FOR USE WITH
Nomenclature (NOM.): ORD CHASSIS, M-116
F.S.N.: 2330-542-5987
Model (MOD.): M-116
Note:
It took looking up other data plates online (see post #8) to figure out what some of these said.
This next data plate is located on the passenger side of the frame near the hitch, and reads:
DELIVERY DATE: NOV 60
INSPECTED: (Illegible stamp)
SHIPP...(illegible)
C...(Illegible)
2...(Illegible)
CU. ...(Illegible)
This is the older style of the Pioneer Tool trailers. The trailer needs a total restoration, tear down, sand blast, weld a few rust holes (though not as many as you'd think), paint, and of course the rubber top hing drilled out and replaced. It still is a fairly solid and straight trailer though. The body metal is thicker than I expected just by looking at it.
Quick run down on the trailer issues or mods that's been made or I will need to make:
Pictures!
Data Plate says:
ENG 7&8
Serial (SER.): 533
FOR USE WITH
Model (MOD.): M-116
Note:
(Illegible) | EMPTY | CROSS COUNTRY | HIGHWAY |
P...(Illegible) | 1500 | 2250 | |
WHEELS | 1225 | 2640 | 3360 |
DG. LEG | 115 | 200 | 230 |
TOTAL | 1340 | 2840 | 3590 |
SHIPP...(illegible)
C...(Illegible)
2...(Illegible)
CU. ...(Illegible)
- The Military lights are long gone. The plug has been cut off and the harness on the left tail light has also been cut. It probably could be spliced back together and made workable, but if a complete (like new?) M116 wire harness could be found I'd just rather go that route.
- The front landing gear is there, but it's a bit rusty and doesn't want to move much, so at some point someone welded on a standard civilian trailer jack - which works well though.
- The emergency chains are a couple links too short for my Dakota's hook up points. Will need to cut a link and add a few more.
- The hand brakes are missing (just the handles/levers). They'd normally be below the diamond plate Kobalt tool box. But the rest of the components are there. Maybe I can just mount the "newer" style hand brakes outside the frame. The right-side hand brake cable is broken at the axle end.
- The left-rear recovery/tie down shackle is missing. I found a loose one in the Kobalt tool box but it doesn't fit, it's a little too large. Also, it's pin is slightly bigger than even the pins used on the deuce rear tow hooks.
- The left front fender has been bent inward and damaged. Should actually repair alright though.
- There's dent in the top of the right gull-wing.
- As mentioned earlier, and not surprisingly either, the rubber hinge needs replacing.
- Of the two doors in the back, the right door is missing its bottom latch, and the exterior hook to keep it open, and where that hook would clip to stay open is broken.
- Needs new tires, the sidewalls are cracked.
- Still has the 5 lug nut split rim (exterior locking ring) original wheels (that I've read were the same as the M37?) I'm hoping to go with tubeless wheels. Maybe 3 and have a spare on the trailer. My Dakota also uses a 5 lug nut pattern but I wouldn't imagine that they're the same.
- Looks like it has oil shocks, and at minimum, the right one is leaking. They'll need replacing.
- Disposal of the interior particle board boxes from former carpenter.
- Weld close and grind a few small interior rust holes in the floor. (This will be a great opportunity for me to "cut my teeth" on actual vehicle restoration, and a final motivating factor to buy a welder).
Pictures!
