- 1,124
- Athens, Ga.
I'm mounting a set of 395s on a set of the Hutchinson 20"x10" 20-bolt rims that I think are Caiman and/or MRAP.
I have a leak on two of them and both are right at what I assume is part of a CTIS system. I find it unlikely that the wheel o-ring is leaking in the same place on both rims, so it has to be the CTIS module. I tried replacing the 2 o-rings in the modules with what I had in stock but mine were way thicker than the originals. Tried re-using the originals w/ some sealer and it helped but they still leak.
Does anyone out there have the right o-rings? Since these are old, I don't know what their non compressed thickness was, so I can't order a generic.
Thanks
C
![20180918_140251.jpg 20180918_140251.jpg](https://www.steelsoldiers.com/data/attachments/508/508736-54f3d18862bcbe32f7498b2f45a1d939.jpg)
![20180918_134700.jpg 20180918_134700.jpg](https://www.steelsoldiers.com/data/attachments/508/508734-a4927bfca164e71da87649f3cd6c8c9c.jpg)
![20180916_172110.jpg 20180916_172110.jpg](https://www.steelsoldiers.com/data/attachments/508/508733-84a0608f4ce16a3cdfefaca575e6977b.jpg)
![20180916_170535.jpg 20180916_170535.jpg](https://www.steelsoldiers.com/data/attachments/508/508732-8a3a0e102ee02d8dbe208ea5b0089432.jpg)
![20180915_193834.jpg 20180915_193834.jpg](https://www.steelsoldiers.com/data/attachments/508/508519-7bde3b929776da473a7a1d991816d609.jpg)
![20180918_140248.jpg 20180918_140248.jpg](https://www.steelsoldiers.com/data/attachments/508/508735-95d2b8cffc4a4b4b7f3364edd0edb2f3.jpg)
![20180906_153012.jpg 20180906_153012.jpg](https://www.steelsoldiers.com/data/attachments/508/508514-5227f887d954575d3e48d9badc2eb8c6.jpg)
![20180906_152936.jpg 20180906_152936.jpg](https://www.steelsoldiers.com/data/attachments/508/508510-668570347a42923ca61749c87abb4749.jpg)
![20180915_174020.jpg 20180915_174020.jpg](https://www.steelsoldiers.com/data/attachments/508/508517-f2c18a081b8cefea4149b576e041c767.jpg)
Also, I need one of those weird two piece nuts that is used to attach the rim ring. Anyone have an extra?
![20180918_134721.jpg 20180918_134721.jpg](https://www.steelsoldiers.com/data/attachments/508/508737-6e00920b30e584e0ff31601617a57547.jpg)
Thanks
C
