For sale: Only bringing items if pre sold!
M989a1 HEMAT trailer, 90% tread on all 4 tires, $2000 obo
M1061e1 5 ton dual axle fuel trailer w/600 gallon aluminum fuel tank, 50gpm Scott fuel pump powered by slave cable, comes with fuel gallon meter and dispenser nozzle.
$3000 obo
M105A2 mint condition restored, extended frame with front deck plate, LEDs, MINT S250 shelter with breaker panel installed, 30amp RV plug with 25’ whip, M35a3 wheels on 14.5s and good spare tire/wheel included. Lots of upgrades across the entire trailer. Reduced to $3500
Trucklite LED tail lights and front turn signal set (4) lights total in mint condition
$300 obo
(2) M931 stainless steel fuel tanks 50 gallons each, very clean and ready to go.
$300 each or $500 for both obo
M939A0 spare tire carrier assembly and crane for 11.00r20 tire size
$125 obo
(2) Hunter camfire 60,000 btu diesel/oil fired clean air heaters, exhaust exits upwards and warm air blows towards you.
$250 for both (one is a parts unit)
M35A2 starter, used takeout $150
MRAP steel round fuel tank DOT rated $200 has sending unit in tact
MRAP miniature aluminum fuel tank $125 includes sending unit
Large diesel high flow muffler $50
MRAP intake assembly with air filter and spinning pre cleaner $100
M37 blackout light assembly stripped and primed $20
(13) total 9.00x20 NDTs with tubes and flaps
(2) are BRAND NEW never mounted on a truck
(3) are less than 40% tread
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
are 65-70% tread
(A couple are mounted on deuce wheels)
$625 obo
(11) 5 ton split ring wheels
$5 each or $40 for ALL
M939A0/M939A1 stubby jackshaft between tranny and t case, good U joints
$200 obo
M939A2 series front driveshaft w/good u joints $100 obo
Interests:
MTVR parts
90% + tread 16.00 XZLs 2014 or newer no flat spots
M35a2 air shift transfer case
M35a2 air shift case install
M35A2 New 2 hole injectors
MEP803A generator
Freightliner SEE
Cranes/Wreckers
Large, newer civilian pull-behind campers
