wgtactical
- 316
- 63
- Carrollton, Georgia
Has anyone came up with a cross reference for shock absorbers for LMTV? I see Fox has some but they're evidently in limited supplies.
Monroe Magnum | 65485 |
looking at your Fbook... looks like you have 6x6 rear axle. or is that a high pinion newer single LMTV axle?? .. if 6x6 is it staying 6x6 with your mods... or ??Has anyone came up with a cross reference for shock absorbers for LMTV? I see Fox has some but they're evidently in limited supplies.
thanks for update on the other Monro Model. I know the 65485 one has been used successfully... maybe cause they are a bit stiffer than OEM?. The OEM appear to be, even at new...... extremely soft. The 65456 should then be even betterThe possible issue with that Monroe 65485 in the parts listing is it is several inches shorter than the original shocks.
the specs for the shocks(A0 anyway) are:
20.94” compressed to 33.26” fully extended under 16mm bolt on one end. Thats 12.32” of travel…
5/8”/16MM top and 7/8”/22MM bottom bolt shank diameters. This shock dimension was obviously chosen for the expected range of travel
Something like a Monroe 65456 @ 20.25“- 32.88” might be a better match for the expected range of travel. Monroe specs them for class6-class8 trucks so the weights are in the ballpark… You would of course have to fab bushings/spacers to match up with the mounting bolts, but that is going to be true of most shocks you choose…
here is a link to one of several threads on that subject…
https://www.steelsoldiers.com/threads/lmtv-shocks-absorbers.140362/
Well they are pretty HD shocks, it might also be that the ones in use havn’t been hammered enough off-road to beat them into submission…thanks for update on the other Monro Model. I know the 65485 one has been used successfully... maybe cause they are a bit stiffer than OEM?. The OEM appear to be, even at new...... extremely soft. The 65456 should then be even better
have got a set of monroe when they were on sale long ago. .... and handled a set of (not mine) NOS LMTV ...... good bit difference in stiffness.Well they are pretty HD shocks, it might also be that the ones in use havn’t been hammered enough off-road to beat them into submission…
Mine is a modified A1R. Only need the rear shocks.helps to know what truck you have. Do you have A1 with coil front shocks or older A1 and A0's with no coil shocks.
My high pinion axle is a modified 6x6 axle. My intentions was to purchase a ready to use axle and I am confident the gentleman who sold it as such thought that was what he had. After having to cut five of the six brackets off and properly locate them, I can now consider myself qualified to do anotherlooking at your Fbook... looks like you have 6x6 rear axle. or is that a high pinion newer single LMTV axle?? .. if 6x6 is it staying 6x6 with your mods... or ??
been there done that. Send you a private messageMy high pinion axle is a modified 6x6 axle. ...
