Doug D.
- 27
- 18
- Winterville Ga
I have read alot about the keyed ignition switches not being any good. Do they know make one that is any good?
A keyed switch can be used to interrupt almost anything.Can a keyed switch be used to interrupt the 24v feed to the factory switch? That way if the factory switch happened to be toggled when it's not supposed to it wont send power to the GP and can't start the vehicle. Not exactly sure how the switch wiring is but thought it might work.
The problem is the switch would have to be rated at quite a few amps and to be able to interrupt a 24V circuit, that is the issue with using a keyed switch for the start/run switch to begin with.Can a keyed switch be used to interrupt the 24v feed to the factory switch? That way if the factory switch happened to be toggled when it's not supposed to it wont send power to the GP and can't start the vehicle. Not exactly sure how the switch wiring is but thought it might work.
@Milcommoguy has the diagram for what you are trying to doCan a keyed switch be used to interrupt the 24v feed to the factory switch? That way if the factory switch happened to be toggled when it's not supposed to it wont send power to the GP and can't start the vehicle. Not exactly sure how the switch wiring is but thought it might work.
Perhaps it could, if you used the keyed switch to provide a ground for a relay, and the relay interrupts the load. The relay would have to be pretty heavy duty, so maybe a solenoid instead.The problem is the switch would have to be rated at quite a few amps and to be able to interrupt a 24V circuit, that is the issue with using a keyed switch for the start/run switch to begin with.
The issue there would be if you forget to turn off the keyed switch the relay/solenoid will drain the batteries, there is a cable to lock the steering wheel that is pretty effective in preventing folks from driving off with your truck.Perhaps it could, if you used the keyed switch to provide a ground for a relay, and the relay interrupts the load. The relay would have to be pretty heavy duty, so maybe a solenoid instead.
Someone designed a mechanical keyed switch which adapts to the existing starter switch. Its supposed to retain the reliability of the OEM switch while still utilizing a key. Unfortunately I can't seem to find a link, but I remember seeing it on a Facebook group.
Otherwise, just go with a hidden switch as others have suggested.
Schwend Waterjet, Welding, & Fabrication
I just bought one and will be installing it this weekend in my sons truck.
