oddave715
- 0
- 16
- Lexington, North Carolina
Something like on the m1028 w/ the contact body and duals but simpler.
It's doable without a doubt. That entire skirt above the tire is just that, a skirt. For me, height was a consideration on the original one so I went with the A2 axle and 235 tires. As it turns out, I have the same style body on a truck and I need something to stand on anyways to reach into the top areas of the side boxes. I keep one of these http://www.harborfreight.com/step-stool-working-platform-66911.html in the back opened up all the time. Easy to toss out and get what I need. Many days I wished I had kept the trailer but the truck actually works out better.I think it's doable. Last night I measured the a3 chassis with hmmwv tires and the bed. It looks like you will have to take a little metal out of the outside of the "wheel well" that is built into the body. It would be easy to make a small flare out of angle aluminum and rivet it on. The hmmwv tire measured out to only about an inch beyond the sheet metal.
Since you are doing away with the welder, consider this platform. It really works out nice and slides in and out on the existing tracks.
I agree. I should have kept the A3 axle under my build but at the time I didn't think to run the 235s. I did put the 235s on my M101A3 and they work great. The slide out bench is great and you only have to use the leg if you are going to crank on the vise. Leg is off an M101.If you use the A3 axle with cucv wheels then height should be the same. Then you get the extra width of the A3 axle, which I like. I feel like the A3 axles width will help with its road manners as it is a big box that sits up high.
