M923 air leak
goldmd
I’m a new M923 owner and I’m looking for a little help diagnosing an air leak. My truck seems to be running great, but air is leaking from what I think is a thermostatically controlled valve on the top of the engine. There are 2 air lines that run to this valve - I believe one is a supply line and it looks like the other runs to the fan clutch. Can some please help me identify this part so I can start looking for a replacement? I have attached a photo with the part in question circled. When the truck is running, air pours out of a small port in the front if this part. Any help is greatly appreciated. Thank you.
Beerslayer
53
Tualatin, Oregon
I don't know what that thing is but I have been reading the TM in preparation for the m923 I am picking up next week. Will see if I can find anything.
Igor Chudov is a member here, and has the Technical Manuals put out there for anyone who wants them.
Thanks Igor!
Here is a link to a search for m923 on his site.
The first five or so links that come up are relevant.
You are going to need them :smile:
goldmd
Thanks for the info. I've been through those manuals, but can't seem to find the part. I must be looking in the wrong place. Lots to learn with this one.
goldmd
OK, I think I found it. Looks like the fan actuator valve. Now I just need to locate one.
Barron
Arizona
If you want to drive the truck you can block off the supply line, locate the 2 handy bolts with plastic washers under them screwed into the casting above the fan pulley, unscrew the bolts and bolt the fan to the pulley via 2 index marks on the fan clutch and pulley, and you have a direct drive fan to get you around. Neat huh? They thought of everything, except I haven't found the Toaster oven yet..
Moosemcnally
Page AZ
I know this is an old thread but for the newbies like me it may help. I just had this same problem. I took it all apart and cleaned it up and it works perfect again. No replacement was needed! It was just gunked up a little bit but the plastic seat wouldn't take much to stick open.
archmark
20
Woodway, TX
I gotta think that if nobody like NAPA carries it, then Cummins must. Guess I'll try taking it apart and cleaning it, AFTER I find a replacement source.
Thanks...
Mark
