20 Inch deuce tires for a m37
Has one of you guys ever welded a center of a m37 rim into a 20 inch duece 1/2 rim. Looking to try to have someone to make a set for a truck I'm throwing together. I personally love the look it gives the truck that is why i want to do it..any help would be nice...
EagerBeaverM35
San jose, California
Hey, Did you get any good ideas for using M35 rims on your M37? I have plenty of M35 tires/rims to adapt to my M37... It does not look like an easy adapter plate (5X6.875 to 6X8.75 interferes). I may replace five M37 studs with press in nuts and press six studs into counter bored adapter plate... Ideas?
Special T
21
Wetside/ WA
The easies route to do this would be to get a hold of 20" container chassis wheels because they have no center and are dot certified. Anyone with a plasma burn table should be able to burn you out the centers you need. You may need to do the welding up yourself as many outfits dont want the liability or charge a good chunk of change because of it.
