2012 M1097A2 starter
New Level
NM
Just purchased and the starter, at least I hope it’s the starter and not the fly wheel, is bad.
Best place to purchase and does anyone know the part number by chance.
Looked at install online and it looks like a PITA to replace.
Thanks in advance for any feedback.
Mogman
8,589
Papalote, TX
Welcome to the forum!
Describe what issues you are having.
The number I have is 2920-01-507-7423
Mogman
8,589
Papalote, TX
If it is the starter you would likely be better off having a starter shop rebuild it.
You need to pull the flywheel cover and see what is going on.
Also numbers 2920-01-168-7891 and MFY-6701UT come up, as far as I know all HMMWV starters are interchangeable
  • Like
Reactions: OBX
New Level
NM
Thank you very much for your help!
TNDRIVER
436
Cleveland,TN
Starter engages but just a loud whining noise. Sounds like all the teeth are missing or gone.
Removing the small cover at the nose of the starter I think will provide all the bad news you seek. Starter spins but doesn't engage, starter comes out. Missing teeth on the flywheel, flywheel comes out. Flex plate actually, before someone corrects me.
New Level
NM
Won’t be back with the vehicle until next weekend. That info helped a lot. I’ll look at that first.
papakb
1,187
San Jose, Ca
Welcome to the forum! Hopefully all your going to need is a new Bendix gear. Still a PITA to change but infinitely less than a complete starter or a flywheel. $25 vs a couple hundred.
New Level
NM
Replies on this forum have been very helpful.
Thanks for the welcome!
Sent a buddy to go move the Humvee to a better spot in my yard…..he figured he would try and start it. It started first try and he repeated it four times and it started immediately without any hesitation all five times.
thoughts?
